DPF
Mileage to service and DPF
Well I’ve been on the motorway regularly so thought DPF problem solved but now find that not doing motorway as much I have no service mileage indicator at switch on and doing local driving I don’t get DPF full light.
The car did tick over quite high recently and a motorway trip brought it back to normal.
I never liked the DPF light coming on but now I don’t have it I’m wondering what is causing that?
Thanks for any advice.
New DPF
Well finally got the DPF changed out. Took 5 hours total with rusted nuts causing the delay!
Anyway the car went fine for a few days but now the DPF full warning comes on regularly even on the motorway after driving at 70 mph for over an hour. I just drop gears, to up the rpm and it clears within six minutes only to happen randomly again.
I did not go to a dealer to adjust the cpu for a new DPF.
Would the EGT or the DPF sensor be the fault?
thank you.
thank you.
