I have a problem with my Jag, Many faults comin up
Hi everyone, I got a issue with my Jaguar xf 2011 3.0 Diesel, There are many faults popping up when reader is connected no mechanic is giving me a right solution if any one can please please have a look and help me.
Engine control - 7BA / Diesel EDC 17CP11
Status :P006A - Intake manifold pressure / Air mass meter.
Error Message : Malfunction. Historical fault.
Status :P00BF - Air flow meter (bank 2) / Air mass meter (Bank 2).
Error Message : Mechanical fault. Historical fault.
Status :P00BD - Air flow meter (bank 1) / Air mass meter (Bank 1).
Error Message : Mechanical fault. Historical fault. Status :P2269 - Water in fuel indicator.
Error sporadic. Status :P2459 - Diesel particulate filter: Frequency of the function <Particulate filter regeneration>.
Error Message : Too few signal changes
Error sporadic. Status :P2452 - Particulate filter: Exhaust gas differen. pressure sensor 1.
Error Message : Installation error.
Error sporadic. Status :P2192 - Lambda control: Control adaptation of upper load range (bank 1).
Error sporadic. Status :P22D2 - Turbocharger solenoid valve Turbine inlet.
Error Message : Specified position not reached.
Error sporadic. Status :P22CF - Turbocharger solenoid valve Turbine inlet.
Error Message : Component sticking. Error sporadic
Thanks,
Sekhar
UK
Thanks,
Sekhar
UK
Best if you post in the thread for the XF & XFR as below.
https://www.jaguarforums.com/forum/xf-xfr-x250-44/
GGG (12-01-2023)
domey
10-09-2014 02:46 AM
