Jaguar X type AC noisy - help needed
Hi guys, I have a 2.0 diesel X type and when the AC is switched on and the centre of the pulley on the compressor goes around it sounds like there is a very noisy rattle from the engine. It is OK when AC is not on. any ideas, and can this be fixed without replacing the compressor.
It usually happens with the diesel x type when the auxiliary belt and tensioner require replacement. The extra load from the a/c highlights the problem. There is an uprated pulley/tensioner kit available from Jaguar for about £200. I'm told fitting it is a nightmare.http://www.ebay.co.uk/itm/GENUINE-JA...60865331451%26
JimC64 (10-02-2012)
Quickest, and cheapest way is turn up at a Ford garage and ask them what they think is causing the noise. Ask for a quote. I'm pretty certain it is likely the pulley system, the symptoms you describe are typical of the common fault. With the a/c switched on the engine sounds like a JCB tractor. Lessen the load and the engine quietens down. Not as quiet as the day the car rolled out of the showroom, but a lot quieter than with a/c on.
Tomcat, thanks again. I have taken your advise and purchased a new crankshaft pulley and tensioner. I will fit these before messing around with the AC compressor. It will be great if the pulley and tensioner fix this problem, but I have the compressor to replace just in case. I will let you know how I get on after the weekend.
Just in case I do need to change the compressor do you know anyone who could advse if the radiators need to be removed as access to compressor is not a lot.
Access to the auxiliary belt pulley/tensioner is certainly restrictive. If you manage that job, all others should fall easily to you. (There may also be a long line of x-type diesel owners making a beeline to you.) Best of luck. I am unaware of anyone who has had cause to replace the compressor so can't further advise. Dozens have heard the noisy engine syndrome when the a/c is activated, all have cured this with the new tensioner kit.
Compressor and tensioner
Hi guys, just posted a similar post to this (before i read here). I have got to have a new ac pump as took to be regassed and pump was diagnosed as faulty. Also have the notorious rumbling from the tentioner. Can anyone tell me if the ac compressor is easily accesible to get a serial/part number to match up as the garage want it in for 3 days? Also, how long does it take to refit the pump and also the tensioner?
stanjag
08-30-2015 10:35 AM
swarm27
08-29-2015 07:37 AM
Terrance Williams
08-26-2015 11:50 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
