Jaguar XF S Sportbrake Self-Levelling Question
Hi everybody and hopefully you can help with the following:
The ride height on my 2014 Jag XF S sportbrake is sitting high on the passenger side with the front left at 410mm with rear airbag at 420mm. The right driver side is sitting just at tolerance front at 376mm and rear at 384mm.
As the left is sitting high should I adjust and lower the front left coil suspension (coilover) to get back to tolerance, with the rear then self-adjusting to suit the revised front? I am assuming that the rear self levelling air system works on what level the front springs are sitting/fixed at and then adjusts to suit?
Any help would be gratefully appreciated.
Cheers,
Paul
Cheers,
Paul
Can't help you with that particular question so it would be worth going straight to the XF forum pages rather than restricting yourself to the UK side of it; wealth of information out there.
Strangely enough, our neigbours annoying family turned up in their Sportbrake R again today, most irritating.
Skinny, skinny tyres, huge potholes everywhere.
edankeven
11-30-2014 05:39 PM
