Manchester area specialists
Hi everyone.
Is there an independent Jaguar specialist that can be recommended around the Manchester area? My 2008 XF currently suffers from the following;
Battery drain
Passenger door lock fault
Exhaust leak (possible flexi pipe)
Cutting out at high speed under load (possible turbo actuator)
Petrol Flap actuator fault
hence the need for a specialist but not main dealer.
Thanks in advance.
Battery drain
Thanks in advance.
If you're prepared to travel the 80 miles to Nottingam, David Marks Garages (David Marks Garages - About Us) is one of the best independents you could find.
The following 2 users liked this post by GGG:
Paul_59 (09-05-2019),
SteveSheldon (09-02-2019)
There is Horner & Hudson in Macclesfield. I have used them and they are very good.
https://www.hornerandhudsons.co.uk/
mile high
12-12-2018 03:36 PM
