New UK Region Member
Hiya to all the UK members. I've just become the proud owner of a cat
I'm in North Lincolnshire and looking forward to learning all I can about the Jaguar.
I've been reading through the forums and have picked up a lot of very useful info already (P0174/0171 codes)
Still confused as to wether the key fob can be replaced without recording as I did read the early cars don't need it doing. The one i have looks like it's been chewed on lol
Look forward to chatting
Regards
Steve
Regards
Steve
Leapingcat2013 (01-06-2014)
Received 9,010 Likes
https://www.jaguarforums.com/forum/s...-guides-41364/
Good luck
Hiya Gentlemen,
Thanks for the warm welcome
Graham,
As it stands at the moment I have one key and one fob unit. The problem I have is the fob looks like it has been eaten by a hamster and the buttons work when they please. I did consider some key blanks from flea bay but then read a post which put me off! At some piont I will need a spare key and fob so as to allow the better half to use the cat.
I did read somewhere that the early S Types did'nt have a programmed key but think this may not be true
Graham,
I think all the S-Types fobs will need programming but best bet is to ask the question in the tech section:
S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum
A check on ebay turned up plant of 'repair kits' consisting of a new case and buttons. If the guys in the tech section can confirm the guts of yours will swap over without reprogramming, it's a cheap solution.
zdrapec
09-25-2015 05:49 AM
