Number plate size
Number plate size
Hi, just wondering what the smallest legal size is for front number plates as looking at doing the grille thing and lowered plate on my xk8?, while on the subject what do you consider the best size for the rear as I don't really like the contoured one that fully fits the aperture?, cheers, Al
To comply with British Standard BS AU 145d the standard oblong number plate size is 520mm x 111mm. The short standard oblong is 370mm x 111mm.
Digit font, size and spacing is also included in the relevant regulation Statutory Instrument 2001/No 561:
Character height = 79mm
Character width (except the figure 1 or letter I) = 50mm
Character stroke = 14mm
Space between characters = 11mm
Space between groups = 33mm
Top, bottom and side margins (minimum) = 11mm
Vertical space between groups = 19mm
A legal registration plate allows very little flexibility in size. The only alternative is 'show plates' which can be any size, font or spacing you like but are not legal for road use.
I never liked the contoured plates for my XK8's and used standard oblong with a border as i do only my current XK.
InverStype (01-08-2015)
Interesting subject! Question: Are stick-on front number plates of the specified size (both plate and lettering) legal in the UK? I am in the process of building a Jaguar based Ronart, apart from the fact it would look totally out of keeping, the shape of the nose cone does not really facilitate the mounting of standard front number plates, as ground clearance would be a problem.
UK number plates
My e-type number plate has only four digits and is, therefore, much shorter than normal. I have never had a problem with either police or MOT's in over 40 yrs.
Paul B.
I must admit that I much prefer the contoured rear number plate as per my S-Type. It fills in the pressed shape of the facelift boot area very well and looks more finished than an oblong plate would do.
Here's a picture of the S showing the No.Plate.
Regards,
Inver.
Gerard Radimaker
09-13-2015 10:33 AM
Richard_gib
09-12-2015 07:08 PM
