UK Suppliers of Parts and /or Services
Hi All, I am going to try to compile all the recent information on here into a useable format in the next few days (maybe weeks lol) such that wherever you are in the country you can find recommended links for what your cat needs. I'll do the same with this as when I run threads for meets etc with the latest post always containing the most upto date listing. It would be great if anyone who has good service, and/or great pricing could post the info up on here and I'll add it into the compilation..
Below you will find the current list of recommended suppliers, as recommended by you! Entries are listed by location (alphabetically) I guess if we get enough I can start to list them by county if you find that better to work from. Each entry has the alias of who recommended it and when - it may be worth contacting them to see if they still recommend the supplier, before going with the supplier. Obviously the newer a recommendation, the more current it is and likely to be accurate! If there is a demand for it I can likely list phone numbers or web addresses against entries..
List of Recommended Suppliers
Location - Recommended Supplier \ Recommended by & Date of Recommendation
Local:
Andover -Thruxton Jaguar \ Steve M 13-03-14
Bristol -Filton Central Garage \ aardvark64 13-03-14
Doncaster - H A Fox \ Jimbov8 14-03-14
Doncaster -The Jag Specialist \ JimC64 18-03-14
Falmouth - Jag Spec. Greg Lummis\ Robiz 04-08-14
Glasgow -Prestige Jaguar \ JimC64 & Kingfisher 13-03-14
London - Les Pauls\ Ngarara 15-03-14
Norfolk - Alders Classics\ Steve M 30-06-14
Portsmouth - Jagcare \ Jimbov8
Stockton - Jagtech Ltd \ GGG 14-03-14
UK Wide:
Event Tyres \ National \ Steve M 09-09-14
If you have had great service from a supplier when having your beloved Jaguar repaired, serviced or parts supplied for it why not let other members know? Pop a post on here, p.m. me to get it added, or even email me at stephen.sheldon@solidlinux.co.uk and I will get it added for you.
Local:
UK Wide:
Local:
Brighton & Hove - The Automatic Gearbox Specialists \ SteveSheldon 17-09-14
UK Wide:
Local:
UK Wide:
JimC64 (09-17-2014)
Received 9,010 Likes
Local:Andover -Thruxton Jaguar \ Steve M 13-03-14
Called out to see Dougie & Ian at Prestige today, a few issues to check with my car.
New premises are looking great, stowed out with work, more than they can shake a stick at.
6 lifts now and some new personnel.....All good!
The following 2 users liked this post by JimC64:
Steve M (12-02-2014),
SteveSheldon (12-01-2014)
I've had various issues with my car for some time, some looseness from the rear end at speed, a wheel wobble and a wandering across the road, the steering bot quite as precise as it should be, all was not well.
Today I decided to be more proactive ahead of my visit back to Prestige Jaguar for another few minor issues to look at and visited a company fairly local to me, luckily enough.
The company is Premier Tyres in Hamilton 01698 424478 and I spoke with Keiran and Callum, 2 very friendly and helpful guys who really seem to know their onions.
The equipment used?
Hunter GSP9700 A 4 wheel alignment, laser guided, pressure testing, rim runout, balancing all singing all dancing machine.
So much more than a standard wheel balance and alignment!
The issues before......
1. A wheel judder when braking, more than likely discs or bearings I guess but we'll see how it may or may not affect this.
2. A slight wander, pulling to one side
3. A vague feeling from the rear, very loose at high speeds.
I'd had enough and it was time to get this resolved.....
See more and for details here...https://www.jaguarforums.com/forum/x...acking-137776/
Premier tyres
Fullwood ind est
Burnbank road
Hamilton
ML3 9AZ
01698 424478
The equipment used?
Premier tyres
Fullwood ind est
Burnbank road
Hamilton
ML3 9AZ
01698 424478
Ok, so its time for a list of good local dealers or Indys for the UK.
Please add any good dealer or Indy garages here as recommendations for others.
Glasgow and surrounding areas
I can certainly recommend Prestige Jaguar
See details in link above and my post here Front suspension work done!
Mackie's Transmissions ZF GB A1 Rated partner Forum meet & Mackies Transmissions Factory tour 29TH MARCH 2014
I cant recommend these guys enough, certainly worth contacting, or travelling to see them.
Please be sure to let them know you're a Jaguar forums member for the best attention / prices
List of recommended garages
1. Prestige Jaguar Glasgow ( JimC64)
2. Filton Central garage Bristol ( aardvark64 )
3. Thruxton Jaguar Andover ( Steve M )
4. Jagtech Ltd Stockton ( GGG )
5. H A Fox Doncaster ( Jimbov8 )
6. Jagcare Portsmouth ( Jimbov8 )
7. Les Pauls London ( Ngarara )
8. The Jag Specialist Doncaster ( JimC64 )
9. Prestige Jaguar (Glasgow ) Kingfisher
10. Alders Classics ( Norfolk ) Steve M
11. Jaguar Specialist. Greg Lummis ( Falmouth ) Robiz
12.Premier tyres Hamilton Hunter 4 wheel alignment specialist
13. Mackie's Transmission specialists ZF GB A1 RATED PARTNER ( Glasgow )
im with jim on recommending jaguar prestige in paisley. having spent a small fortune in the last two months in getting my xk , serviced, new rear tyres &pads as well as mackies transmissions gear box serviced, tax and ins, noticed that one off my rear tyres was flat took it to f illing station to put air in. 14psi its a new tyre only 3weeks old should be 33psi. got her home jacked it up looking for a nail found one. but also found back end off car which had been making a rattling noise on the way to the station was coated in oil. im no mechanic can do a wee bit .it look like it was coming from the diff. yep was right, so on advice phone up prestige jaguar. dougie couldn't have been nicer bring it in right away Charlie he said. drove to paisley wife on tail found the workshop wow busy place jags new and old . salons convertiables, coupes busy work shop. explained to dougie and he confirmed my worst fear yep its the diff. left the xk with the boys and expecting the worst (Thursday this week) phone prestige jaguar on Friday lunch time. got good news it was the seal that was away. thanks to the big yin and to dougie no damage to the diff cought in time. picket the car up this morning sat. and owe them another thank you for allowing me to collect on sat as they don't open. very very happy and a big thank you from me to all at prestige in paisley. charlie
JimC64 (04-25-2015)
#32
I'm from the East Midlands and wanted to recommend this Jaguar specialist garage:
Nottingham JagTech
2 Little Tennis Street, Colwick, Nottingham NG2 4EN
I've had bits and bobs done from them including brake calipar repainting, alloy wheel repair and a battery change. Including getting lots of general advice on issues that I have had. I've found them really helpful and unlike some garages who simply don't care, these guys actually look like they care.
Great option if you can't go to the main dealer too.
Nottingham JagTech
#33
Local:
Glasgow - Mackie's Transmission specialists ZF GB A1 RATED PARTNER \ JimC64 27-02-15
Glasgow - Prestige Jaguar \ JimC64 & Kingfisher 13-03-14
Hamilton - Premier Tyres 4 wheel alignment specialist \ JimC64 27-02-15
Nottingham - JagTech \ apachegogo 05-05-15
UK Wide:
Local:
UK Wide:
#34
SteveSheldon (05-11-2015)
#35
Local:
Rotherham - Rotherham Jag Centre \ Smoggyx100 11-05-15
UK Wide:
Local:
UK Wide:
#36
Great thread Jim & Steve.. Does anyone have recommendations (or warnings!) for the Cambridge area? I'm looking into Nene Jag Specialists (Peterborough), Jagutek (Ely) and Roach Classics (Sudbury) but would welcome any advice... For a service / post-purchase check on a 2002 XKR.
SteveSheldon (05-15-2015)
#37
Guy,
If you don't get any recommendations for your immediate area, it's always worth considering traveling to get your Jaguar to a recognised specialist. As an example, when my XK requires a transmission service, I'll be doing the 160 miles from Durham to Mackie Transmissions in Glasgow simply because they are the experts.
One of the World's best Jaguar independents is David Marks Garages in Nottingham, around 90 miles from Cambridge ........
#38
#39
#40
Thanks Jim
By the way, I noticed the mod list to your Audi in your signature... have you thought about LED installation in your Jag? I'm trying to compile a list of compatible bulbs...
(sorry if that's drifting off-topic - I can post somewhere else if you prefer?)
JimC64 (05-24-2015)
