x type 2001
x type 2001
hi
i have a x type 2.5 v6 2001 the car has started to cut out when i am going down the gears when the clutch is dipped. iv had it on the diagnostic machine but not sure if its a lambda sensor and witch one it is. (this is my local machanic not a jaguar specialist,) do you have any ideas because its expensive to replace all four and not sure if that will cure the problem
thanks justin...
thanks justin...
KarimPA
09-03-2015 07:32 PM
