Headlight Polishing Ft Lauderdale
It is so very easy to do this yourself, depending on the degree of fading and buildup there is on your lights. If they are just slightly opaqued, use a little wax with a fine kitchen scuffing pad. A little elbow grease should do the job.
For the really faded lenses, buy a headlight restore kit at the auto parts store. Buy a brand like McGuires that has the sanding disks with it. You will be basically "wet sanding" the lenses with fine grit paper, then polishing with a wax. Amazing how well this works.
A little work and they will look good as new!
Vtjaguarlover
12-06-2015 04:09 PM
danke
10-05-2015 11:04 PM
cash5ive
10-04-2015 11:41 AM
