US Mid Atlantic MD VA DC DE WV
Virginia XK8/Aston lumper
Old 01-08-2012, 10:59 AM
John Fox's Avatar
Hey Ronnie, tried to call you says your voice mail is full. Check your PMs I forwarded my number, call me when ya get a chance.
Old 01-09-2012, 10:27 AM
Ronnieb883's Avatar
Default Progress
I took the car down from jackstands. Cut the rear drivers qtr panel off and moving on to the trunk area today. I'll get y'all some pics.. Garage is big and my heater isn't enough! Freezing my *** off in there.. R
John, I'll give you a call. Parts are just collecting dust, all yours..
Old 03-02-2012, 03:45 PM
Ronnieb883's Avatar
Default Status update
I blame winter and work! Finally got the quarters and trunk cut off. Here's some pics. Cut the passenger side quarter with a grinder/cutoff wheel and the driver's side with a sawzall (didn't want to use a grinder on the drivers side due to the fuel vent line being right below the quarter skin.
Old 03-05-2012, 09:23 PM
Ronnieb883's Avatar
Default More pics..
I found some deals on wheels. Heaven forbid I go out and buy some original Aston wheels and curb check them! I was tempted though; they look nice! You can see the wheel boxes off to the left, XXR brand 527 style... Cheap! ($650 shipped!) basically 18x10 & 18x9 rims. Craigslist Goodyear Eagle F1 Supercar takeoffs from a Shelby GT 500 (500 miles on them). 285/40r18 & 245/45r18.. ($400!) I won't be crying if I curb rash these! Got my Vantage/DB9 tail lights ready to go....
Old 03-18-2012, 09:12 PM
Green01xkr's Avatar
Any updates yet??
You plan on using spacers to get the wide body look? 18x10 doesnt seem wide enough??
Old 03-28-2012, 09:14 PM
Ronnieb883's Avatar
Hey all. Yes, I finally got the panels mounted. Not fun or easy either! Pics to come.. As far as wheel spacers, I'll be using 1.25" wheel adapters front and back. R
Old 03-30-2012, 09:17 PM
Green01xkr's Avatar
Nice... What offset are your wheels? looking into getting a similar set.
  #28
Old 04-02-2012, 08:53 PM
macc24's Avatar
......waiting.....patiently.
Old 04-04-2012, 09:02 AM
bryce804's Avatar
Me too!!! Ronnie you should quit your job and focus on this conversion!!!
  #30
Old 04-04-2012, 09:13 AM
bryce804's Avatar
Whoops
Last edited by bryce804; 04-04-2012 at 09:16 AM. Reason: accidentally hit post twice
  #31
Old 04-04-2012, 11:49 PM
Ronnieb883's Avatar
Default Wheel info, updates, and pics....
Hey, all. Yah, I wish I could just up and quit.... Navy wouldn't like that and probably come looking for me.. Thanks for the interest in the project.
Green: From what I've found, the original 17x8 "Revolver" wheels came in 33mm offset. Those ghetto 20's on the car now are Ruff Racing R280 models 20x10 & 20x8.5 but I now can't find the offset specs anywhere and they may be discontinued (can find 5x120 but not 5x120.65). I think they were 20x10 30mm & 20x8.5 25mm and if you see below, factory numbers show opposite offsets. I'd trust the factory numbers IMO. You can see by the original pics of my car, that the front fender lips were rolled so I really want to trust the numbers below.... The XXR 527s wheels I got are both 20mm and I can almost assure you, they'd rub your front fenders at least. 527s are super-stretch tuner wheels for that "hella-flush" look (garbage in my opinion) and designed to put the wheel out into the fender lip but they have the GT1 look and specs I was looking for. I'll be mounting the tires to them sometime next week and can give you a better idea then (at least on the back wheels). Stay tuned. Are you thinking of getting XXRs for your car?
factory wheel offsets
18x8: offset is 33
18x9: offset is 35
19x8: offset is 33
19x9: offset is 35
20x9: offset is 30
20x10: offset is 25
Passenger Door pics:
Second picture shows my original dilemna. I could not get the kits door line to follow the original Jaguar's door line. It looks like it should work but doesn't. The first pic shows as good as I could get the alignment. Notice that 3/4" gap up front between door and fender? Yah, like that on both sides. Notice the nice, tight gap initially at the top of the door and then it gets wide and tight again along the door bottom? Yah, something else to fix... More tomorrow.. R
Green01xkr (04-07-2012)
  #32
Old 04-05-2012, 12:08 AM
Ronnieb883's Avatar
Default How it fits, now how to make it look acceptable.... :(
  #33
Old 04-05-2012, 04:11 AM
bryce804's Avatar
It looks like the fit of that kit isnt the highest quality. Good luck getting the doors to line up.
  #34
Old 04-07-2012, 09:59 AM
Green01xkr's Avatar
Ron,
Yea, i was looking into xxr, but got bigger fish to fry right now.. Busted tensioner with driver cams possibly skipping gears... PANIC MODE...
  #35
Old 04-07-2012, 11:47 AM
Ronnieb883's Avatar
Default Tensioners = YIKES! Rear end pics...
Green.... Man, I hope it's not the tensioners. John Fox talked to me about them and he said you can pull the valve covers and see the tensioners enough to get an idea of their condition and whether they're the newer designs. What kinds of sounds are coming from the engine? Able to do the repair yourself if it's just the tensioners? Crossing my fingers for ya!
A lot of area to fill and blend! I read claims from CarKitInc that you can maintain an operating trunk, but I had to wack the back face of the trunk off.... We shall see..
  #36
Old 04-07-2012, 02:06 PM
Green01xkr's Avatar
Deff tensioners issue... Found loose pieces inside when i was getting ready to replace valve cover gaskets due to oil in plug wells causing cylinders to misfire.. Car was shaking like a maniac on idle...Researching the project to see if i have the bollocks to do it myself...
  #37
Old 04-07-2012, 02:13 PM
Green01xkr's Avatar
Just a suggestion, but it looks to me that extra height on the rear quarter is identical to the shortage on the door jamb.. Cut the side skirt on the bottom of the door jamb an you should be able to drop the quarter panel down which will automatically raise up the door side and fill the gap..it should be easy enough to get the side skirt to fit...
  #38
Old 04-07-2012, 08:28 PM
Ronnieb883's Avatar
Default trunk stuff...hmmm
Good thought, Green. I'd been going off this build:
And, then I found this picture which points more toward what you're saying:
I like the Vanquish S rear look. It has a centered dovetail instead of the straight across arch. I went back out to the garage and looked at the rear end. I'll just have to make it work, just another compromise I'll deal with.. R
  #39
Old 04-08-2012, 04:42 PM
Green01xkr's Avatar
Regarding those wheels, did you get the right HUB specs or you will correct that with spacers?? Cant find any XXr's with our hub (74.1)
  #40
Old 04-09-2012, 11:45 PM
Ronnieb883's Avatar
Default Bad Jurid/flex coupling. Pic
I'd noticed the driveshaft coupling was bad but did realize how bad. Talk about dangerous! Wound up having to take the driveshaft completely out; pain in the butt with the car on jack-stands.. Going to weld up Exhaust tomorrow and I'll be done with the underside of the car!
Green, I know the wheel adapters I'm using are 73.9mm so I'll probably be able to just sandpaper them out to our hub spec. Shouldn't take much at all.
Jorge526 (03-13-2014)
Quick Reply: Virginia XK8/Aston lumper
