Virginia XK8/Aston lumper
#42
#43
#44
#45
#47
#51
Hey, all. Got the wheels mounted on the car finally. So, here's my new dilemna and the picture tells all. There's a difference in the Vanquish/XK8 wheelbase by 3 or 4 inches and I guess it's becomes very apparent in the rear wheel well. I also included a collage pic of some other kits pics but their wheel well issue isn't nearly as apparent as mine.. I guess I'll have to just shift the wheel well forward. Very tempted to yank the Independent rear and go solid axle as I looked underneath and don't see any way of moving the IRS rearward and don't want to undertake lengthening the driveshaft..
![](http://img6.imageshack.us/img6/6018/rearwheelissue.jpg)
![](http://img24.imageshack.us/img24/5460/ashmartrearwheelwells.jpg)
#53
#55
#56
Strange. Have you sent pics to the manufacturer of the kit and asked him to weigh in? Either it's not fit correctly and needs to be shifted forward or it's fit correctly and others have likely complained as well. If so, I'm sure that some "standard" or suggested fix is known.
If I was there I'd be glad to help out, since I'm interested in knowing how big a headache this kit is. Still considering one myself.
#57
It hits me that if you can find someone good with fiberglass they could reform the arches properly moving them forward, likely far cheaper (particulalry before paint) then trying to move the axle. And you could fix the front. Not trivial though by any means but it could be done. Fiberglass is used to modify wheelwells but the issue typically is that it doesn't work that well long term with a metal body (faster and cheaper though) on a fiberglass body it is likely the ideal solution. But you'd want someone who isn't learning on your car.
#60
Hey. Thanks for the interest RJ. I've been working on moving the rear end back some to fix the tire/wheel well issue. The IRS has about 1.5" of room and the driveshaft extends out that far... Alot of work but it'll have to do until I pull the rear eventually.
Lights. I bought some Gatling gun shrouds and projector lights. Probably get these amber halo lights and use them a parking lights.
![](http://img10.imageshack.us/img10/7185/gatlingshrouds.jpg)
![](http://img837.imageshack.us/img837/120/amberhalo.jpg)
