Need new Valve Cover Gasket Replaced
I have a 2002 Type S 4.0, the passenger side valve cover gasket needs to be replaced. Can anyone provide how to approach this job? Breakdown sequence special tools needed, and other miscellaneous parts needed besides the gasket?
Al little about the car, it is a 2002 with 57000 miles on it. the gasket is not the only problem, all the rubber suspension components are dry rotted and need to be replaced. This car was my mothers, and when she passed I was given the car. As you can see it was barely driven, and stored inside in FLA.
The dealer wants $13,000 to fix the suspension and leaking gasket, so I am trying to do the small stuff to cut the cost down. I have already replaced two ignition coils, and some smaller items.
Any comments from sell the car to how to reproach fixing it would be great!
The Region forum is a good choice if you are looking for advice on recommended Independents in your area. It's not the best place for posting tech questions if you are looking for advice on how do do the work yourself. The S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum is the place for help and advice on your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
vinnylamp (02-23-2015)
