2004 drivers side headlamp not working on low beam standard lights,
You need a handbook for your car that shows all the fuses or the electrical wiring diagrams which I think can be found in this forum.
https://www.jaguarforums.com/forum/x...ownload-10582/
Look in the above thread.
Another possibility are the grounds located near the headlights. If not properly grounded due to corrosion they can cause issues. They break easily so be careful if you look at those grounding studs.
Kyd
16
07-03-2016 09:58 AM
