anyone in Massachusetts?
Wmass X Type
Chicopee MA here, 03 xtype auto with 86,000 miles .
Anybody now a good dealer to get work done at in Wmass? the Hartford deals a rip.
I have ended up doing alot of work myself. like
oil changes
air filter, cabin filter, fuel filter
drive belt, waterpump belt
coolant resevoir ( nipple leak)
rear brakes, disc and pads
prop shaft grease
Stuff i need to do is,
rear swaybar bushings, Transfer case fluid change, and maybe a transmision fluid change, also might need a propshaft replacement (i still get a little hum even though i grease it every time im under there)
oil changes
prop shaft grease
Wats up guys, I'm from Woburn.
I just bought a 99 XJR(101000). I love the car but, something is wrong with it, every time i hit a pothole i think the car is going to stall out.
SILVERCAT idk if you know this, but if you work at a dealer, you get a discount at any dealership. I used to work for jeep and got discounts at all the dealerships.
#28
oil changes
prop shaft grease
oil changes
prop shaft grease
oil changes
prop shaft grease
oil changes
prop shaft grease
#30
#31
Just some of the information I've been able to find, there isn't much and I haven't done much more than bookmark them at this point:
http://www.j-a-n-e.org/cgi-bin/membe...temp=main_page
http://www.jcna.com/
I think that's about it...
#33
#34
#35
#36
#37
One of the consequences of not using a Jag dealer direct and using a foriegn car specialist is parts can take a bit of time to be acquired as the foreign car location has to get parts through the Jag dealer. Foreign car specialists are not going to stock a lot of parts. Motor Cars Int. would have to go through Hanover Jaguar in Hanover, MA or Jake Kaplan in Norwood, MA. In additon to the time the dealer has to get the part this could add several days to the time your car is OOC if the part is not in stock at the dealer. The part can cost more through the foriegn car specialist as the dealer will mark up the price by 10% over cost to the foreign car specialist. The foreign car specialist will then mark up the price 30% over retail...this might offset any labor savings...
#38
good to see theres a bunch of people from MA here, we should all meet somewhere central...
anyways the x needs both rear wheel bearings, which ill replace this coming wednesday, four new tires and four new shocks, which are coming on the 12th, put new pads and discs, an oil change and an alignment and the cat is ready to go
also the dealer in norwood gets me good prices, never been for service but being able to get a discount in parts is always welcome.
pce
pce
#39
#40
