New Hampshire checkin in
#41
#42
#43
#44
#45
#46
#47
#48
#49
#50
Any chance you are ever "down South" that I could check out your car? I could also travel to you. I'd appreciate it very much.
#51
#52
JohnK, I run studded snows on my 98 XK8 in the winter and call it a snow cat. Until the snow is high enough for the under carriage to start plowing, I can keep up with the pesky AWD subarus, and look much better doing it. She has no problems dealing with NH winters at all with the new snow sneakers.
#53
jagyankee (01-09-2014)
#56
I am not sure if the S has DSC or not.
If it does, then all 4 wheels have to have the same tires, 4 snows or 4 regulars. The amount wear, size and brand should also be about the same on all four.
The concept is the computer reads how fast the wheels are turning and the steering angle. Going straight all 4 wheels should be rotating the same RPM's. If not then it assumes your are drifting or hydroplaning and compensates for it to keep the car stable. It gets weird if you are not drifting or hydroplaning.![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
