Inactive suspension 2011 XF
Hello I’m from Tx and have a 2011 XF supercharged. That needs some work done. I had a coolant leak coming inside the car under the carpet and came to find out it was the heater core connectors leaking. After removing the dash to see where the leak was coming from. I just went on an replace the heater core, txv, & evap so that should not be a problem anytime soon. Next was the control arms lower/upper & forward was replace. And now I’m getting an inactive suspension on my scanner tool. I check fuse ( good) can not find a relay chart. Check the wires/ voltage to shocks connector an nothing is out. I also check the adaptive module voltage 14v going in and 2-5 coming out. I need help!!
