jr member needs help with motor mount xj(x300)
I was able to remove the motor mount bracket on passenger(rhs) side by removing 3 bolts and lifting the transmission with jack...was thinking smooth sailing until I tried to remove the mount it is threaded on both sides and seems to tighten down into the frame...i;ve been trying to loosen it from the frame with vise grips with no success
![Icon Omg](https://www.jaguarforums.com/forum/images/smilies/icon_omg.gif)
the bracket that holds the actual motor mount(passenger side) has 3 bolts and I had only removed 2 the third bolt is not easily seen because its on the bottom and was difficult to remove I removed it and the bracket came right off...then i just removed the nut holding the actual motor mount removed the old mount replaced with the new mount and then replaced the bracket
1964Daimler
09-09-2015 11:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
