93xj6 left heater blower
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi newby with second problem, car is a 93xj6 with 140.000 miles runs like a Jag should, I had a problem with not enough air coming out the vents so I found that the left blower was running at low speed, I dissabled the blower housing and bench tested it werkt fine cald a friend of myn and he told me that the transducer located in the blower housing was bad, also that the are no longer affable any how an other friend found them ($10.00), in the meen time check blower motor closer, brushes where worn and armuter bedly worn, a rebuild was $250.00
so I found a Toyo blower in my back yard and with some minor werk I was able to fit it in the housing so all this was simple, now the problem, fuse is good bud yet no power to the brown connector whith the brown and black wire, anyone that can help please???? Tony the Dutchman.
![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
