Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
2005 str rims
Old 04-19-2011 | 09:54 PM
99snake's Avatar
Default 2005 str rims
Where is the best place to buy and what is the bolt pattern? What other cars are compatable and will wheels off any s type or other jaguar fit? Thanks.
Old 05-11-2011 | 10:50 PM
Michael Star's Avatar
Not sure where to get them, but the bolt pattern is a 5x108. I think Volvo has the same bolt pattern.
Old 05-13-2011 | 12:09 AM
pokey's Avatar
Volvo does have the same bolt pattern. The offset and wheel bore might be different. You could always get hub rings, but you would still have to get the correct offset. Custom wheels will always work!
Old 05-14-2011 | 11:24 PM
qwiketz's Avatar
I just spent hours on this... they are 5/108 with high offset. I've seen different numbers quoted for for the str you're probably looking at 40 offset on the front and even more on the rear. Ferrarri, maserati, and I think volvo share the pattern. There aren't any cheap wheels that are staggered for our s type r.
Old 08-08-2011 | 07:19 AM
ffhillclimber's Avatar
I measured my '05 STR wheels yesterday and got backspacing of 6.75" front and 7.50" rear. That works out to a offset/ET of 57mm, if I figured correctly.
Old 08-09-2011 | 06:32 AM
kmk's Avatar
kmk
Original Vulcan wheels have ET60, front and rear.
Impossible to find correct spec aftermarkets...
robbing
03-05-2024 11:51 AM
Larry-Cleveland
02-09-2019 04:17 PM
redxk8
10-04-2015 09:28 AM
Johnken
10-02-2015 11:12 AM
Johnken
10-01-2015 06:07 PM
Quick Reply: 2005 str rims
