offset?
A change in offset will affect your suspension and steering geometry.
A 0.25 inch change is probably not much to worry about.
Be aware that changing offsets will also affect tire clearance.
tirerack.com might have some FAQ articles and offset charts to help you.
BTW, if you change to a wider wheel/tire combination without changing offset, the geometry does not change. Tire clearance is another matter.
Stock offset is 33.
Use this calculator to see what happens:
http://www.1010tires.com/WheelOffsetCalculator.asp
mohrd (03-03-2011)
