Snow Tires on XJR
Snow Tires on XJR
Bought a 2005 XJR the other day, and have not heard one good thing about the all season Perelli P6's on the factory 19" rims.
I can get a set of 18" rims fairly cheap, can I use Bridgestone Blizzaks in a 245/50/18 without an issue? If I reaseached correctly that should be a plus zero size. any experts can you confirm or advise before I make a purchase?
drcase (06-19-2011)
Mike Im in the same boat, Just bought an 04 XJR. From what I have researched, you need an 18x8.5" deep rim to clear the brembos, kinda a PITA to find, I thought about getting salvaged rims from car-part.com but for the amount id spend on 18" rims, I can just get some Blizzak's for the 19's for under $300/each mounted. those are 245/40/19
Let me know if you find anything different in your research
Jeff
Jeff
