Suspension Upgrades
Suspension Upgrades
Interested in wringing some more performance out of the Jag suspension? Or perhaps just upgrading your deteriorating bushings to bring it back to stock levels? Either way, here is some good info.
The 4.0 model jags (think late 90's early millennium) suffer from deterioration in the upper shock mount causing "clunking" and poor alignment.
See this link for pics https://www.jaguarforums.com/forum/s...light=bushings
Here is a link to a replacement aftermarket (read cheaper) replacement.
shock mount
http://www.motorcarsltd.com/MJA2170BD.html
As for the rest of the suspension, nothing will tighten up your old jags suspension like some new poly bushings. It's like botox for your suspension
Poly bushings
http://www.paramount-performance.com...n_Systems.html
http://www.powerflex.co.uk/products/XK8+XK8R-2611/1.html
shock mount
Poly bushings
2004 -2009 XJR or XJ8 AIR SUSPENSION REPAIR,,, Note XJR uses the sport Suspension...Air Suspension Part... $1500/wheel from the dealer... see this site below ... for $399/wheel and they come with a LIFETIME warranty. Just order some and will try to update this after they have been installed... PS... cost to install is $329 here in Humble, TX.... Makes what would be a costly repair a LOT less painful..
http://www.arnottindustries.com/part...20_pid136.html
That's a good question, however I'm not sure anyone here has the answer. You might be better off calling the manufacturer or at least a retailer. You could always post it up here for the betterment of the community as well. -Shaun
OK from my LR days .. Red = Stiff/Hard, Orange = Softer, Blue = Softest.
But for more info : http://www.polybush.co.uk/polybush-grades
And for Jaguar : http://www.polybush.co.uk/shop/299_Jaguar
But the links in Squirrel's (Shaun) OP at the top are also good.
And you may want to check out the forum Vendor Nalley Jaguar.
driver safz
09-26-2015 06:01 AM
BlacXJRcat
09-25-2015 06:43 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
