Sway Bar Bushings... Clunk, Clunk
I replaced the sway bar bushings on my XJR this morning. With a little advice from Jag Genius, I went ahead. This is a very simple and inexpensive task. After removing the two bolts on each side, the mounting brackets and old bushings pull right out. Installation of new, just as easy. Best of all, the clunking from the front end is gone.
Thanks JG!
(The JTIS manual suggested a much more involved procedure)
I imagine there are other clunker XJ's on the road that could be fixed that easily.
Thanks JG!
The job is very simple. After removing the undertray to get access to the sway bar, you will see a pair of brackets that mount the swaybar to the cross beam. Each bracket has two bolts that hold the swaybar and bushings to the chassis. Simply remove the bolts, brackets and rubber bushes. If the bar is rusty, clean it up with a bit of emery cloth.You can apply a bit of vegetable cooking oil to the inside of the new bushes if you like. I was advised not to use mineral oil. Push the new bushes onto the swaybar, place the brackets back over them and bolt them back on. Don't tighten until you have both brackets installed, then torque to 30 - 40 Nm.
It is hard to tell with a visual check, but if the car clunks when steering back and forth in a tight zig-zag fashion, that is a telltale sign. You may have the same clunking sound when going over uneven ground. The old bushes may look fine, as mine did, but the new ones silenced the clunk. This is probably the easiest and least expensive remedy, however before you start you may wish to take a quick look under the hood at the upper shock bushings. If they have deteriorated, you will be able to see that visually. Apparently that (and other sources) can also produce a similar noise. I did not need to replace shock bushings, as mine looked good. Hopefully you will find the same situation, as that job is more involved.
Thanks JWT! Much appreciated.
I tried the tight zig-zag and did not hear any noise, oddly enough I only detected the clunk when going a slowly over an obstacle, like a ramp or curb... the upper shock bushings look ok.
I'll try to replicate the noise again, but today I thought the sound might be coming from the dashboard... need to investigate some more.
jaguar04, I would definitely take your particular question to the x-type section for some assistance. Although the XJ and XK suspensions of similar years share some suspension features (and often issues such as this) I think the X-type is much different and can't use the same historical references such as this thread as a go-by.
Good luck.
Good luck.
Hi Guys,
just wanted to contribute towards other possible causes. I had the same problem with my car; clunking sound coming from the suspension while going over uneven ground.
I fixed my clunking problem by replacing the FRONT SWAY BAR / STABILIZER LINKS and REAR SWAY BAR / STABILIZER LINKS. I mean, I have a few bad bushings but these two did the job and the car is now quiet, pretty amazing actually because it wasn't hard and wasn't very expensive.
So, check the Front and Rear Sway Bar links as well, because, it solved my clunking problem. I'm planning on replacing the front sway bar bushings as well, just haven't gotten to it yet.
Good Luck...
Good Luck...
