Tire Maintenance
![](http://s11.postimg.org/6u6ilt1tf/4534.jpg)
Everyone knows that tires play an important role in your vehicle's handling and performance. But many people forget that proper tire maintenance, along with monitoring tire pressure, tread depth and performing regular tire rotations, are all safety issues.
Consider these Car Care Council statistics:
Only 14% of drivers properly check their tire pressure.
Nearly 70% don't know how to tell if their tires are bald.
45% wrongly believe that if taking a trip with a fully loaded vehicle that they're better off with tires that are slightly under inflated.
To help keep you from landing on the wrong side of these statistics, Eurobahn technicians are committed to proper tire maintenance.
Remember, tire pressure should be checked at least once a month.
Well maintained tires help ensure you're receiving the proper level of traction and road-hugging performance; as well as the ability to funnel water out from under the tire to reduce hydroplaning.
Bcrary3 (03-23-2016)
