VelocityAP F-Type Lowering Springs Product Launch
We have signed off on our progressive rate lowering springs for Jaguar F-Type models and are going into production!!!
Ride height reduction is 7/8", or 22mm.
We are launching 2 products - one which fits all body styles and engine types except V8R: F-Type V8S Convertible
And one for the V8R: Jaguar F-Type R Progressive Rate Lowering Springs
During our analysis and testing of the OEM springs, we discovered that all variants had virtually identical spring setups with the exception of the front springs on the V8R. Due to the fact that the engine are all derived from the same basic block, kerb weights on all the cars are extremely similar and so we were able to create a design which works for all the non-R applications.
Info:
VelocityAP springs use exclusively high quality, high stress X5K Spring Steel. Although considerably more expensive than regular steel, this new generation steel allows us to further improve upon the original Jaguar F-Type spring design by reducing the amount of steel required in a spring. VelocityAP springs are therefore substantially lighter (by approximately 30%) and reduce the solid height therefore increasing travel. X5K Spring Steel is used in almost all top levels of Motorsport, giving a hugely successful endorsement of its characteristics & proven durability.
In addition to the superior materials, these springs also feature a unique manufacturing process that sets them aside from most OEM & Aftermarket applications - a Tapered Wire Progressive Rate design. The Ultimate in Design. The principle is simple: By using a tapered rather than constant diameter spring wire, our springs achieve a truly progressive spring rate over the length of their compression & travel. The spring rate increases when you need it (cornering) and decreases when you don't - yielding a smooth and supple ride over bumpy surfaces. The best of both worlds!
By using this unique manufacturing method, we can achieve a substantial increase in spring rate with huge handling benefits with no loss of ride comfort. As the spring de-rates, the shock absorber no longer struggles for rebound control and gives improved vehicle stability.
Benefits:
Info:
Benefits:
- Reduced Weight
- Improved Ride Quality
- Improved Handling
- Better Visual Appearance
- Improved Shock Absorber Function
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Wolfy
05-28-2024 08:06 AM
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
wvanepps
10-04-2015 10:01 AM
