Wheel Bearings
Hmm........ Doesn't sound all that bad. Job involves: -
1. remove road wheel
2. remove brake caliper
3. remove brake disc
4. remove hub
5. press out old bearing(s) from hub
6. press in new bearing(s) to hub
7. put it all back together (1-4 in reverse).
If it is a Jaguar main agent the labour charges tend to be higher, plus you will pay top dollar for the bearing. Here in England, my local dealer, (main agent), has club for owners of Jaguars over 4 years old - anything like that in the US ? Wheel bearing jobs should be within the capabilities of normal jobbing workshops, there is nothing special about the Jaguar front wheel bearings as far as I am aware. I did my own once on a 1980 XJ6, rear ones as well.
4. remove hub
Received 2,194 Likes
just be carefull they really know what theyre doing and use the correct type arbors to press in and out. While its not hard, theyre sealed bearings and if they distort the thin metal shield that covers the bearing between the inner and out races. This lets water in and will destroy the bearing eventually. problem is it wont be right away so you wouldnt link the 2 together andd just chalk it up to a bad part. If memory serves me. I believe its 2 2.5 hours but I dont have access to Alldata at home
I'll tell you what I did. I had 2 wheel bearings that were toast. I took 2 wheels off another model, a salvaged car. I knew they were good. It took 1 1/2 hours for the front. The rear took 22 minutes. That includes taking them off the salvaged vehicle. Both wheels were 45 a piece. Now many of us can't do that. But you can always check with a salvage yard, they will pull them for you. Your mechanic can install them. Especially for those of you that drive newer Jags. The insurance companies total these cars quickly. Even though the parts are still great!
Richard_gib
09-12-2015 07:08 PM
