Would 16" 5-spoke rims from '94 XJS fit on '92 XJS?
Trying to determine if the wheel in the first photo (16" by 7") could be a replacement for the the second one pictured, the 15 x 6.5 or 15 x 7 lattice type wheels on a '92 XJS, without any mods or issues. I've seen the bolt patterns for both listed as 5 x 4.75, but I haven't been able to find a definitive answer as to offset, etc.
Received 10,920 Likes
Should be a direct swap. Not sure about the offset but, if there's a difference, it won't be enough to be of consequence.
Check the lugnuts, though. There may not be an issue but Jaguar used several types of lugnuts so make sure whatever type you use will fit the wheel and provide a good purchase on the studs.
They won't be lattice wheels, if that's what you wanted. And there might be an interference problem on the front hubs. Be careful.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
