XJ8 Lowering Springs
Which springs should i go with? The paramount's or mina's? They both lower it 1.2"
http://www.paramount-performance.com...n_Systems.html
http://www.minagallery.com/jagxp/Jag...%20springs.htm
Well what year do you have? And are you planning on installing them yourself? Because for my XJ8, the springs were under WAY too much pressure for me to be able to do them.
And as far as pictures go, I can't figure out how to put them up on the forum or anything. I think it's because I'm a junior member or something. But if you want I can email you a couple of pics of the before and after.
No tire rub, and the ride is definitely a lot smoother and tighter. No more "boaty" feeling around turns. When I did the springs, I also changed the bushings (forum suggested it somewhere). So that also might have helped. But I am very happy with the results. Money well spent. The only thing is that I wish the fronts were 0.5" lower. I cheated in this picture by parking on the downhill. I wish she was stanced like this all the time.
