2003 X-TYPE High Beam Light Problem
dman, odds are, your turn signal stalk is toast and you will need to replace it. Granted, I would assume you have pulled the lever towards you to remove the headlights off of the high beam. If you want to use a multimeter to figure out what is going on, let me know and I will assist however I can. Atleast for the moment, you can make sure the high beams do not come on as you can remove the main beam/fog light relay and that will kill power to the high beams.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
