AC on driver side blows hot, passenger side blows cold
After charging up the AC, the driver side blows hot, passenger side blows cold. I'm being told that the compressor needs to be replaced. There is a leak that sounds like it's coming from the compressor. I'm also being told there are two sides to the compressor and that is why there is a difference in the driver and passenger side.
i would get a 2nd opinion, doesnt make sense that the compressor is divided into 2 sections, i would think it posible drivers motor out or something else tht switches the motors on. I'm havign similiar problems my self ezcept my ac fan motors wotn kick on high they run on a very low speed, the air comign out is ice cold 95 xj6 4.0 eng
Mine did something similar a few weeks ago, I had to remove the battery to replace a worn waterpump belt and belt tensioner, when I hooked it back up the AC blew hot as in the heater on full. Here was my fix after figuring out the AC was working and the compressor was turning on (which yours does since it is working on one side) I figured I had a vacuum problem or a computer problem. So the 1st thing I tried, which worked was a I reset the computer completely by disconnecting the battery overnight. The next morning it blew ice cold again and has for over a month in 90+ summer temps.
I know it is a pain to reset the windows and everything else, but for a no cost DIY test, and if it fixes the problem that is a small price to pay.
And yes I work in IT so my first instinct is always reboot the system.
Received 6,361 Likes
Might be your fan controller. The fans may not be blowing full speed when you are stopped. If you are not getting air moving across the condenser the system will not cool.. Could be why it works when you are moving..
I can tell you exactly what may be wrong with your car because I had the same problem with mine. My car initally would only cool when the car was in motion, but when idling it would become warm again. Turns out I needed a new compressor which cost me (well dad) about $1400 bones...but sometimes you can find them cheaper online. After the compressor was installed by my dad's mechanic, I noticed the passenger side was blowing out cold and my side was warm. The AC system needed to be recharged....(there wasn't enough of the fluid that makes it cold in it). So most likely, you just need your system recharged.
Dicque
09-19-2015 12:53 PM
OkieTim
09-08-2015 04:48 PM
