Cable not connected, where does it go?
Hello everyone I am needing some help. I recently took my air intake off to replace the intake manifold upper and lower seals because of a check engine code. I also replaced the spark plugs and replaced the valve cover seals and the coils. I put it back together and went to start it up. I get power and can hear clicking but it will not start. I opened the hood again and found a wire not connected. I can not for the life of me find where it goes to. It comes out from under the battery and off the cable that connects to the positive battery lead. I have all the other plugs in and there is on connection even close to it. I will upload a pic generalizing the area. I think the green arrow points to the cable. I will check and confirm. if anyone could tell me where it goes I would be more than thankful!
![](http://i293.photobucket.com/albums/mm51/mikenmikena/car/DSCF3350copy.jpg)
Hello everyone I am needing some help. I recently took my air intake off to replace the intake manifold upper and lower seals because of a check engine code. I also replaced the spark plugs and replaced the valve cover seals and the coils. I put it back together and went to start it up. I get power and can hear clicking but it will not start. I opened the hood again and found a wire not connected. I can not for the life of me find where it goes to. It comes out from under the battery and off the cable that connects to the positive battery lead. I have all the other plugs in and there is on connection even close to it. I will upload a pic generalizing the area. I think the green arrow points to the cable. I will check and confirm. if anyone could tell me where it goes I would be more than thankful!![](http://i293.photobucket.com/albums/mm51/mikenmikena/car/DSCF3350copy.jpg)
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
The plug is for the battery isolation device that was removed from the car when the PDI was performed by the selling dealer. It plugs into a blank plastic connector behind the battery. The battery needed to be disconnected for the long journey accross the Atlantic on a freight ship and the isolation device performed this task.
bob gauff
bob gauff
hafren
09-07-2015 10:30 AM
