Coolant Leak
Old 07-02-2010, 03:56 PM
compdude97's Avatar
Default Coolant Leak
I have coolant leaking on the bottom of my car, I took a picture of where it looks like it is leaking from, It looks like that black piece is a rubber seal, is that true? If so is that where it is most likely coming from? that is what it seems like to me. What is that seal called, how hard is it to replace, and how much should it cost?
Thanks,
-Compdude97
Old 07-02-2010, 07:34 PM
compdude97's Avatar
Is it the water rail gasket?
Old 07-03-2010, 11:56 AM
compdude97's Avatar
Anyone?
Old 07-03-2010, 02:47 PM
Jagking's Avatar
the black piece in the picture is the thermostat housing. There is a gasket there but i would just change the whole housing. I believe it comes with the upper hose and thermostat. Just make sure its not leaking from further above where the water pump is located
Old 07-03-2010, 03:46 PM
SMT's Avatar
SMT
SMT is offline
I have changed the gasket on that connector, its very cheap but is quite a time consuming job working manly on your back from under the car, but its doable. I'll dig the part number out if you need it.
Old 07-03-2010, 05:30 PM
Tony_H's Avatar
Did you crack hosing when tightening thermostat bolts?
Old 07-04-2010, 09:19 AM
compdude97's Avatar
If you could dig up the part number that would be awesome. I didn't change the thermostat so I didn't crack the housing, I am positive it is that gasket, it stops leaking when it cools down and starts when it heats up.
JagKing, it isn't leaking from the thermostat gasket, it is leaking from the black gasket to the right of the themostat, I believe it is the water rail gasket, but want to confirm that belief.
Old 07-04-2010, 04:48 PM
SMT's Avatar
SMT
SMT is offline
The part number for the seal (gasket) is C2S11282, it cost less than £2 here in uk.
Old 07-05-2010, 05:54 PM
compdude97's Avatar
Thanks, too bad my dealer isn't open today. Oh well I will just have to skip out of work early tomorrow.
Old 07-05-2010, 10:58 PM
ghettomike's Avatar
thermostat housing...its more common than you would think....while you are doing that just do the thermostat at the same time.. its only $20 more.
Old 07-07-2010, 01:19 AM
Jagking's Avatar
never said it was the thermostat gasket i said it was the thermostat housing but make sure its not the water pump further above
Old 05-02-2012, 07:16 PM
pcarrott's Avatar
Default Water rail gasket leak...
compdude97,
Did you successfully make this repair?
Does it require a coolant system drain?
I have a slow leak in the exact location and ordered the gasket today.
Had the thermostat replaced a year ago, so I was just going to replace the gasket and not the whole upper hose.
Old 05-04-2012, 11:32 AM
pcarrott's Avatar
Default thermostat gasket
Originally Posted by pcarrott
compdude97,
did you successfully make this repair?
Had the thermostat replaced a year ago, so i was just going to replace the gasket and not the whole upper hose.
anyone??
arskemp
09-21-2015 02:19 PM
Lannyl81
09-19-2015 08:07 PM
OkieTim
09-08-2015 04:48 PM
Xkr x100
09-06-2015 08:50 AM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Coolant Leak
