Door Card Clips
You mean these buggers;
![](https://dl.dropbox.com/u/11575086/30102011841.jpg)
Everytime you remove the door card, you are guaranteed to break at least one.
I had every door apart for my speaker upgrade & replaced about 10x all up.
They come in different colours, supposedly each colour is a slightly different length but don't ask which is which...
Brown C2S33673
Green C2S13493 or C2S24976 (changes in VIN?)
Violet C2S33674
White C2S13494
When you took the door card off for the first time, did you notice where each colour was?
BTW welcome to the forum! I've been all over the Balkans but never made it to Sofia...
Brown C2S33673
Violet C2S33674
White C2S13494
Hey Guys
Thank you for you answers. The problem is that i still have not removed the door card since in Bulgaria we do not have those clips on storage and i need to order them first. So this is why i needed to know how much they are to order them. Also unfortunately Moto Phoe Bulgaria are so useless that they can not even tell me which once do i need . So probably I will need to remove it and see and then order them. :} And i do nto have the door trim removal tool maybe i can find it somewhere and order one.
Let's try to get you a little more progress with this. Here's the Parts Manual drawing so you can see what is required:
![](https://www.jaguarforums.com/forum/attachments/x-type-14/22715d1345449775-door-card-clips-x-type-rear-door-trim-panel-jpg)
There's part number changes dependent on VIN (for Item 3) PushIn Fastener and colour for (Item 7) Screw Cover.
Cambo has already listed part numbers of the four available colours of PushIn Fastener (Item 3) in his post #3 above. The part number you need for these depends on your VIN. The reason for the different ones being available is they are different lengths.
With your VIN, I can lookup the correct part numbers for Item 3 for you but your are going to have to take the panel off to count the number required unless someone posts with this information.
The following 4 users liked this post by GGG:
GGG (08-20-2012)
For VIN Range up to D24745:
PushIn Faster (item 3) is the Green one = Part Number C2S13493
This goes into Insert (item 8) of which there are two types available. Again they are colour coded:
White = Part Number C2S20167
Black = Part Number C2S20168
There's no VIN given against these but it should simply be a matter of checking what it currently fitted.
Lcgi (08-21-2012)
RaceDiagnostics
09-13-2015 02:22 AM
