Fogging up!
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
'Morning, All;
Just recently I've had a problem with keeping my windows clear when the outside temp. is around the freezing point and I have the system in "Auto", and I'm beginning to suspect that the Ventilation system is stuck in the "Recirculation" mode. I have to switch to full "Defrost" to de-fog the windows. Where is the gate that controls the air source located? Can I see it in operation?
Thanks for any input.
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Done, and done! Thanks again Jac. My 'door' was closed tight, and there was moderate resistance to opening it, and it showed no sign of wanting to drop closed again from any open position. There is a 'click' from inside the dash whenever I select "Recirc" (or not) on the climate control buttons, but no resultant action from the door. Either the servo is weak, or a linkage is disconnected, but I'm guessing THAT bunch is well buried under the panel controls. I hardly ever use "Recirc", so I'll just leave well enough alone.
gunlocators
09-30-2015 08:05 AM
rsa760041
23
09-25-2015 01:33 PM
