Intake Manifold
Intake Manifold
I've been chasing vacuum leaks at the engine & I found leakage where the two hard lines go into the top of the manifold, the lines are fairly new but the inserts that you push down to unlock these lines are worn...
What i'm wanting to know is, can these rings be purchased separately & can they be changed by a shadetree mechanic.
Thanks for any and all help/advice
Gary
Gary
Received 3,899 Likes
Yes, the pieces are able to be replaced by just about anyone. I think you are going to find the hard part to be getting the new clips that go in there. I would recommend going to the local auto parts store and look in their miscellaneous parts area and see what you can find. I do not think that they come as part of a new hose assembly.
By the looks of your brake booster hose, you are leaking at the middle "bulb" in the hose, as it shouldn't look all white and cracked like that. If you don't want to buy a new brake booster hose ($70) then you can always get some large heat-shrink tubing and seal over that large area in the middle of the hose.
Nearest Dealer is an hour away in Raleigh
Was this an item that was used by Lincoln/Ford as well?
Gary
I thought the same thing, but when i did the carb cleaner check at the bulb, no change in engine idle.
I did find engine stumble at those inserts on top of the manifold.
Gary
vac lines
The vac lines have what they call "Chinese fingers" to hold the line in,just push down the center and pull out the line, use a small screwdriver to fish out the "o ring" and holding fingers, insert the new one but don't use the brass sleeve because it's pressed in. No need to remove intake just don't break the hard plastic line, it's the "o ring" that drys out and leaks. If it's a long way to the dealer fish out the "o ring" take it to the hardware store with a good selection of "o rings" stick the "O ring" back in.( get the exact size) or you won't get the line back in, also there are black "o rings and there are green/ or greyish ones. Black ones don't hold up under heat as well as the others but at least you will know if it was the problem. Auto stores carry the ones for automotive use.A Hardware store usually has a good selection,grab a 1/2 dozen there cheap.
Seal that check valve up anyways because it will eventually leak even if you don't think it is now.
Kota62 (04-10-2012)
I had the same thought this weekend, and to that end I decided to try the Plastic Dip stuff you put on Pliers and such...
After a few days It's still handling the heat of the engine.
Nothing like preventative maintenance
Gary
keenyoung (05-18-2012)
I bought some o-rings from NAPA last night, unfortunately they were the wrong size (OD) so will try again today, took some pics of what's in there though...
A bit of a struggle to pull the plastic locking ring out since I want to reuse it, but as long as it's not brittle from all the heat you'll be fine
Gary
BTW: Late Model Mercury Cougars use the same system
Gary
Intake vacuum hose o-rings
Hello, Any idea what the part number for this kit is? I asked the dealer, and they said it was discontinued. I can't find the right size o-rings anywhere.
Thanks.
Keen
Thanks.
Keen
I did try the local Ford and Mercury dealers. The kits are obsolete, and the o-rings are not listed separately. The Ford parts guy slapped a box of generic o-rings on the counter, but of course, none would work.
I asked the service guy what his mechanics do when they get a Cougar or Contour in with this problem. His response? "We don't get too many of those in for service any more." In other words, as usual, we know more about the problem than the dealer does.
For now I have two smaller cross section o-rings stuffed in each hole. It seems to be working better than the old hard ones.
Thanks.
Keen
Thanks.
Keen
My twin o-rings didn't work, but now problem solved. After visiting Ford, Lincoln Merc, 5 auto parts stores, and 3 hardware stores, I got a tip about a non-franchise parts store with a good selection of o-rings.
Lo and behold.... o-ring nirvana! They must have had 200 sizes! I selected 3 sizes that were very close to the original, and now I'm fixed. No leaks, no codes, good idle.
Thanks to all who had suggestions,
Keen
Keen
Sweet deal Keenyoung... glad you won
Keen
Keen
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
