just thinking about replacing fuel filter???
The following 6 users liked this post by tony:
Augeter (11-23-2014),
froggy22 (12-01-2014),
Mark Scotton (06-14-2012),
ptaboy (01-20-2014),
SlimGoody (06-17-2014),
and 1 others liked this post.
Received 3,905 Likes
Jaggy, as long as you keep the fuel lines pointed up and don't let them hang down to low, it isn't a problem. Both times I am changed fuel filters (my car and a members car), there was a little bit lost from the fuel in the filter, but that was about it. Have a catch pan under the car to catch what comes out of the filter and you will be fine. You are probably looking at only about 2 ounces of fluid that will come out.
The following 2 users liked this post by tony:
whatshappening01 (09-04-2021)
The following 2 users liked this post by maikal_0011:
Stuart Beattie (01-27-2014)
You get the most clear picture by looking, which it seems you haven't done. If you want people to help you, you have to do more than asking the same question over and over when you already have the answer.
This really is a simple job; I replaced mine at 100K. Pull the two pipes off and unscrew the retaining bolt. About a quarter of a cup of fuel came out of my pipes. It takes about 20 mins max. I didn't feel any benefit when I replaced it, but better to replace if before something does happen.
Sorry to bring back an old thread, but I juts replaced my fuel filter today as well. It was pretty easy and is in the location that everyone is saying.
I'm not sure what special blends off fine herbs you guys were smoking when you did ths though, because "a few ounces" of fuel is an understatement. Both of my fuel lines sprayed fuel all over the place in addition to the 4 oz that I caught in a dish and another several ounces of dirty fuel coming from the filter.
At any rate, after changing the fuel filter out and hooking both lines back up again, expect the engine to turn over a little more than normal on the first start afterwards as the fuel filter and lines fill up with fuel again. I changed my current official Jaguar filter for an autozone filter, and everthing seems fine so far.
The following 2 users liked this post by blaydes99:
Lcgi (12-26-2012),
Did you discharge the pressure in the fuel lines first? You can make a pretty big mess if you take off the filter and the lines are still presurized.
You can either wrap a rag around a small screwdriver, and press the schreader valve on the fuel rail, or you can pull the fuel pump fuse or relay, and crank the engine a few times.
The schraeder valve is usually on the fuel rail - the pipe connected to the injectors on top of the engine. It looks like a tire valve where you yould put the air in. You would push the pin in the center to release fuel pressure similar to letting air out of a tire.
However, I just ran out to my car to take a picture to show you the exact location, on the X-type, and I don't see one! So I would try the mthod of pulling the fuel pump fuse and starting the engine. This is fuse #17 in the passenger compartment under the dash, NOT the engine compartment fuse box. If there is pressure in the lines the engine should start, but stall out after a second to two if you pull this fuse. That should relieve most of the pressurized fuel.
The following 4 users liked this post by Andy94SC:
alan924 (01-21-2014),
jeffmartinaz (05-28-2013),
Stuart Beattie (01-27-2014),
