Little nut on the AC compressor on the front to oil the clutch bearing?
Here is a picture of my AC compressor. It has a little nut on the front. If I take that off does the front come off so I can get at the clutch bearings. It makes noise and when I spray oil on the front and behind pulley it stops, but it is thin oil. I probably need to pack the bearings. Someone recommending take off the wheel inside cover to get at the front of the ac compressor. I just want to make sure if I take that little nut off I can get at the bearings. I might even need to change them.
So you think there might not be any real way to get at the clutch bearings other than having it rebuilt? I was afraid of that. I imagine they didn't design it to be taken apart. I was thinking maybe there is a way to have thicker bearing grease sprayed in if it was melted. It sounds cheesy, but I wonder if it would work. It isn't as bad as before since I sprayed, but gun oil and wd40 are so thin they don't last.
Ok its been a little while ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
As shown in pics below, I used a 13mm socket and a screw driver to remove the "little nut". It was tight but after a couple of attempts the nut came off, an extra set of hands would have helped. The screw driver held the clutch assembly from spinning.
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/11225d1308496070-little-nut-ac-compressor-front-oil-clutch-bearing-dscn6016.jpg)
Once the nut was removed I used another screw driver to pry the clutch spring (cover) off the clutch assembly. NOTE: DO NOT DO THIS! Use hardwood or plastic wedges, the tip of the screw driver damaged the metal clutch pad underneath the spring cover.The spring cover is splinned as shown and it is on there pretty tight.
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/11226d1308496184-little-nut-ac-compressor-front-oil-clutch-bearing-dscn6020.jpg)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/11227d1308496208-little-nut-ac-compressor-front-oil-clutch-bearing-dscn6019.jpg)
Under the spring cover is the sealed bearing and retainer "C" clip. There is no way of lubbing that bearing!
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/11228d1308496235-little-nut-ac-compressor-front-oil-clutch-bearing-dscn6017.jpg)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/11229d1308496266-little-nut-ac-compressor-front-oil-clutch-bearing-dscn6021.jpg)
Hope this helps.
For some reason photobucket is locking up on me, so I am posting pics the old fashion way, sorry!
Hope this helps.
Wow, thank you so much Joycesjag. Thant answers a few questions. I was thinking there was bearings under that that were somehow getting lubed when I sprayed. So there is no way to lube the oil, and the noise coming from there is not the bearings I'm thinking now. It is probably the clutch plate itself barely touching the flywheel(not sure if that's what it's called). When I spray oil it gets between those parts and the sqeaking stops temporarily. Now my question is, how do I fix that? Could I put a different clutch plate on to correct it? It's probably not a common problem.
Thank you again, I really appreciate that.
I think you need to purchase a new or reman compressor. There are 2 different casing styles be sure to get the right one.
Here is a picture of the 2 different casings the shorter bolt casing is for a V8 S Type and the longer for a 3.0
![](https://www.jaguarforums.com/forum/attachments/s-type-15/10372d1305471716-ac-low-side-line-73-lbs-preasure-ac-compressor-comparison-jpg)
The longer casing is approx 4" long and the shorter is about 3.5" long
Here is a link to an OEM for sale here, you want to ask what motor its for:
https://www.jaguarforums.com/forum/p...pressor-56084/
It looks like there is a C clip inside the pulley from your pictures. If that is removed with the pulley slide off? If it does then it is possible to change the sealed bearing. If the clutch plate is stationary and on mine they are rubbing that could mean my flywheel has drifted out a millimeter. I'm sure they are suppose to be super close when not engaged.
It works great now other than the intermittent noise, so I won't change it yet. Thanks for you help. If I could pop it off with a pulley thingy. The thing that has 3 arms and a center that screws down to pull off the pulley. But they probably don't sell just the pulley anyways. Thanks again. I won't do anything since it's working fine.
