Manual Transmission Fluid Change Write up (with pics) FAQ
So as the title explains, this is my write up of changing the manual transmission fluid. First off, I would highly recommend doing this. The reason I had to do this on my vehicle is because changing gears was getting so hard that it wouldn't match up with my natural clutch movement so my car was jerking around and putting more strain on my xcase than I wanted.
Parts:
I bought 2 quarts of redline mt90 full synthetic oil off of ebay (only place that was pretty cheap and I could actually find it.)
Need a 8mm (think that's what it was) Allen wrench
Oil Pan
Jack and jack stands
Tube for getting the oil in the fill hole.
![Name: 2011-10-30_17-28-25_129.jpg
Size: 56.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168772d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_17-28-25_129.jpg)
Make sure you get the parts before you jack up the car so as not to risk having to drive without fluid (common sense, but it almost happened to me
Now locate the drain valve. The picture below is of the drain valve and the wheel is the right front wheel just to help with orientation.
![Name: 2011-10-30_17-31-09_836.jpg
Size: 71.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168773d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_17-31-09_836.jpg)
And it's probably a smart idea to know where the fill valve is before you pop the plug off drain. Note that the picture was taken from the front of the car.
![Name: 2011-10-30_17-29-47_741.jpg
Size: 60.6 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168774d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_17-29-47_741.jpg)
So now it's basically common sense. Pop the drain valve with the allen wrench and wait for all the fluid to come out. Then put back in the drain valve and open the fill valve. To get fluid into the fill valve takes a little bit of patience, but works pretty fantastically using my simple method. All I did was go the hardware store and found the smallest funnel they sold and then found nylon tubing that mated right up to that.
![Name: 2011-10-30_18-10-00_914.jpg
Size: 107.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168775d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_18-10-00_914.jpg)
Then run the tubing through the engine bay and down into the fill plug.
![Name: 2011-10-30_18-12-03_596.jpg
Size: 72.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168776d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_18-12-03_596.jpg)
And just hold the funnel and fill 'er up
![Name: 2011-10-30_18-11-44_707.jpg
Size: 56.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/168777d1501281068-manual-transmission-fluid-change-write-up-pics-faq-2011-10-30_18-11-44_707.jpg)
It does take a while to get all two quarts in, but I think I could have used a larger diameter nylon tubing to make it go quicker.
Hopefully that helps someone out there. I know it's just sorta common sense, but I decided my first write up should be about something that doesn't really have that many tricks
Parts:
Oil Pan
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
The following 8 users liked this post by disguay:
Andahaion (11-08-2011),
blaydes99 (11-10-2011),
Bud Tender (11-16-2012),
Cadillac (11-08-2011),
JimC64 (11-08-2011),
and 3 others liked this post.
Can you clarify the fluid you used?
Your post above mentions both "full synthetic" mtl, and MT-90 (pictured). When I went make my purchase to do this myself I came across MTL (50204) labeled full synthetic, and MT-90 (50304) labeled Manual Trans 90W Gear Oil. Can you help? Want to do this right the first time.
thanks!
thanks!
I only have two jack stands so I just jacked it up from the front. With the location of the drain valve, I don't really think it would change anything. In the grand scheme of things, it's probably only one fluid oz one way or another which doesn't concern me. Also, I only got about 1.5 quarts out, but took a pen light up into the drain and didn't see anymore fluid. Jag says its supposed to be 1.8 liters (2 quarts) so I think I must have just lost some in the 110k miles my baby has been on the road for.
rf69 (01-06-2012)
I just did this on Saturday. It was super easy and only took about an hour. I put in two whole quarts of the Redline MT-90.
The old fluid was black, but not too thin and there was plenty of it, so no signs of a leak.
I will say that it did not improve shifting at all. It's still very clunky going into 2nd. Shifts into all other gears just fine though.
Anyway, thanks for the detailed write up! Going to tackle the transfer case hoepfully next weekend.
