Melted headlight harness info
Guest
Posts: n/a
Hi everyone, I joined this forum in hopes of obtaining some assistance with a melted headlight socket for my gf's car (it's out of warranty).
She has an '04 X-type, and for the second time, a blown low beam headlight has resulted in a melted socket (the part that attaches to the bulb). Last time this happened, the dealer charged $100 to fix it.
I was wondering if anyone knows of a fix for this that wont cost $100 at the dealer, such as where to get the harness, etc. The dealer parts department doesn't sell the harness. The parts dept said the service department has a "kit" for this issue, but they wont sell it.
Thanks!
*I also searched using various terms, but somehow couldn't find a relevantanswer.
Received 9,007 Likes
I'd check the fuse...is it the same side that is melting every time? Did you put in aftermarket bulbs in there or are they stock sylvania halogens? We've experienced many problems with aftermarket bulbs but I've never had a melted harness...sorry I couldn't help for this...
Guest
Posts: n/a
Thanks for the replies everyone; hopefully someone can eventually point me in the right direction with respect to an easy/cost-efficient fix for this issue.
Good point about the fuse; I'll have to check that. Althoughwould the size of the fuse really cause thesocket to melt when the headlight bulb burns out?
Regarding the type of light bulb, yes; they are the stock Sylvania's that came with the car. I've read elsewhere (and a parts department person even admitted) that this is a known issue for the X-type, but I guess only certain X-types seem to have been affected.
![Name: cars.jpg
Size: 7.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/195590d1501336881-melted-headlight-harness-info-cars.jpg)
Aquill........I think as I stated at the time I had one blow after 5-6 weeks. I complained to the supplier who immediately replaced it F.O.C and have no problem this last 11 months maybe?
So I am a happy bunny that can see in the dark....lol
Bucks right about the fuse being the weak point that is designed to blow before anything more important goes bang obviously. May be a good place to start checking.
It was a worry of mine when I replaced the bulbs but my sparky checked the fuses and assured me that they would blow first if there were any problems
Jim
If you are melting harness's, you are pulling too many amps. The stock bulb is not capable of doing this, so the problem is elsewhere. Past the harness is the load.... in this case the bulb. The only other factor to the load is whether or not JUST the bulb is the load. This is obviously not the case since you are drawing past the bulb current rating, you have a second load. The second load is usually a short to ground so check the harness as far as you can trace it. Also, make sure the bulb is not being shorted by the clip that holds it into place. This is most likely the issue, but since the harness is melted there may be a new issue now.
Man that sucks...anyone know where else he could get a new harness? I'm not sure what I'd do in your situation though nk....I'd check at a local import spot and see what they could do for you if they'd be any cheaper than a dealer...I haven't heard that that particular problem was model wide about melting harnesses...the aftermarket bulbs not working or rather blowing days after putting them in I've heard of though!
Jim I can't believe yours have lasted that long...Didn't you pay a decent amount for those jim? Considering I paid like $78 for hids...although they are hids in the mail not with me still...[:@]
![Name: cars.jpg
Size: 7.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/195574d1501336838-melted-headlight-harness-info-cars.jpg)
ORIGINAL: aquill1
If I remember rightly they were about £15 for 2 bulbs
It was around a year ago now though!
Jim
you have to cut both wires off and re wire2 new pinsand put one to the bulb and a new one to the housing tap directly beside the bulb.. and a new bulb of course ... this is a usual for x types over time i think it's the quality and the guage of the wiring .. and they just melt.. dont pull on it or you will damage the inside housing..
Hey nkx1 I have the cure for you. This will be much cheaper than the harness, the lights will look better and be brighter/safer for her and lastly its not much harder than cutting that harness and adding a new one to it. Get a set of hids like I got and nineball and spartan got from this guy on ebay. Unfortunately it took me almost 2 and a1/2 weeks to get but once they realized they didn't ship them out yet and they shipped them on the 19th and I just got them today in the am...so once they ship them it only takes about 5 days to get to you straight from china. The lights cost me 78.99 total including shipping. Look here for what they look like on my car...
Link...
Link...
Hello -
I have the same issue - my left headlight bulb needs to be changed but I was told by the mechanic that the socket had melted...
The dealer said that it will be about $30 for the socket, $15 for the light and about $50 for the labor. The last time I was there for the annual check-up about a month ago, a different mechanic told me that the labor and the lamp would be about $50 combined, and I was told the socket would only cost a few dollars. I was going to go with that but they didn't have the socket in place and hence here I am, a month later, still without the light....
Can someone please give me a sense of how much it should be for the socket and for the lamp? Is there a generic socket and the lamp you can recommend I buy online like from ebay? That way, I can hold down on the cost of materials and just pay for the labor... I just don't want to be paying for it all the time if this is a recurring issue... Plus, I really don't know much about cars, and I think it's quite obvious when I go to dealers... don't want to be completely ripped off...
Any help would be great. Thank you!!!
Jagx-welcome!
To keep from having this happen replace your bulbs with a complete hid kit. Some nearby places have kits now for under $100 or you can go to ebay (well under $100.)
The harness/socket/plug will be cut off when you put hids on anyways. You wont have any problems with the melting socket with the hids and it fixes recurring blown headlights.
If you want one off ebay pick from any of them as they are all pretty similar just read into each sellers ratings.
(this is a link to the exact kit I bought, only $62 shipped, but it is selling under a different ebay account. My guess is that it's the same company as they both have manyadeal on both pages.)
If you want to buy local try looking on craigslist.org and you can probably find a kit on sale in your area and can get it today instead of waiting. Install is easy and can be done for free by yourself.
Received 2,190 Likes
DAMN IT TOOK HOW MANY POSTS (12)BEFORE JAG GENIUS GAVE THE CORRECT FIX, IM ASHAMED OF YA'LL....YOURE SLIPPING. YES CONNECTOR AT AUTO PARTS STORE FEMALE SPADE WITH PLASTIC SHIELD. $5 A BOX. AND YES BE CAREFULL OR YOULL BREAK THE PLASTIC POSTS INSIDE THEN YOULL HAVE TO BAKE THE HEADLIGHTS N THE OVEN TO TAKE THEM APART AND USE STRUCTURAL ADHESIVE TO REPAIR, THEN SEAL BACK TOGETHER. OPEN THE TWISTOFF COVER BEHIND THE HI BEAM, AND WITH YOUR FINGERS TRY TO MOVE THE INNER ASSEMBLY, IF IT FLOPS AROUND ITS BROKE AND YOU NEED TO REMOVE AND REPAIR, IF OK THEN DO JAG GENIUS REPAIR AND BE DONE
Replacing the connector doesn't fix the problem???
We've had more than a handful of people in the last year that have posted about the same thing and being charged at the dealer. IMO it's a bandaid, not a fix.
You fix it with the connector and these people will still have problems keeping bulbs from blowing. [&:]
HIDs are the only thing I've found to actually "fix" the problem! (however legal/illegal they are????)
