my x-type projects and installs
THIS THREAD HAS A LOT OF WRITE UPS ...THEY ARE
1-EASY TRANSFER CASE OIL CHANGE...thread#102
2-TRANSMISSION OIL CHANGE..thread #98
3-HID KIT INSTALL
4-DOUBLE DIN INSTALL
5-ILLUMATION FOR DECK WRITE UP
6- MY X-TYPE IS ALSO LOWERED
7- CHECK ENGINE LIGHT ...LIMP MODE REPAIR...thread #119
8- WIPER MOTOR FIX... POLLEN FILTER WRITE UP
IF YOU GUYS NEED HELP WITH ANYTHING LET ME NO
knew ..coming soon my fibre glass interior project
my grille
![Name: 004-2.jpg
Size: 88.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186510d1501319142-my-x-type-projects-installs-004-2.jpg)
my hids
![Name: 009-1.jpg
Size: 69.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186511d1501319142-my-x-type-projects-installs-009-1.jpg)
my dvd/navi
![Name: 0082.jpg
Size: 159.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186512d1501319142-my-x-type-projects-installs-0082.jpg)
![Name: 010-1.jpg
Size: 188.6 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186513d1501319142-my-x-type-projects-installs-010-1.jpg)
![Name: 4455020.jpg
Size: 90.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186514d1501319142-my-x-type-projects-installs-4455020.jpg)
![Name: 307.jpg
Size: 18.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186515d1501319142-my-x-type-projects-installs-307.jpg)
![Name: 012-1.jpg
Size: 138.6 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186516d1501319142-my-x-type-projects-installs-012-1.jpg)
![Name: light010.jpg
Size: 100.6 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186517d1501319142-my-x-type-projects-installs-light010.jpg)
![Name: 003-2.jpg
Size: 27.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186518d1501319142-my-x-type-projects-installs-003-2.jpg)
Hey Dennis....looks like some nice work you done there as far as I can see.
I've edited your post so that your pics can be seen ( try checking out the "how to" post pics in the Jaguar help n suggestion centre.
As you can see I haven't done all of them as there are a lot, sumthin you can possibly rectify at your leisure. It'd be great if you possibly did a write up on what you did and how you did it to accompany the pics.
Nice one
Jim
3-HID KIT INSTALL
my grille
![Name: 004-2.jpg
my hids
![Name: 009-1.jpg
my dvd/navi
![Name: 0082.jpg
![Name: 010-1.jpg
![Name: 4455020.jpg
![Name: 307.jpg
![Name: 012-1.jpg
![Name: 003-2.jpg
Nice one
Jim
Hi Dennis
Info on dvd Navi please How Much ? How difficult. Where did you buy it from? Write up would be great . Also what wheels are you running on the Jag. Brand type & Size? It looks sweet.
Info Info info.
john.
Info Info info.
john.
im starting a write up as we speak ...and aranging pics for this thread...i have a lot ,i also lowered the the car ill have it post asap
when it comes to my hid process ...the headlights were fairly easy now the fog lights i had to pop the bulb out put it in a vice then drill it out to fit the knew ones which needed the outer part of the housing...the dip beams i orderd from autolumination.com ..194s i got my hid kit from ebay 8000k iceburg blue ($71) i should have pics of install soon
![Name: 011-3.jpg
Size: 123.2 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186376d1501318988-my-x-type-projects-installs-011-3.jpg)
![Name: 010-2.jpg
Size: 92.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186377d1501318988-my-x-type-projects-installs-010-2.jpg)
![Name: light009.jpg
Size: 117.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186378d1501318988-my-x-type-projects-installs-light009.jpg)
![Name: light007.jpg
Size: 120.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186379d1501318988-my-x-type-projects-installs-light007.jpg)
use this wire for the illumination of your deck ...the orange wire from the nexxia adapter is for the dimmer and does not carry a full 12v
![Name: light011.jpg
Size: 97.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186380d1501318988-my-x-type-projects-installs-light011.jpg)
after painting
![Name: 011-1.jpg
Size: 153.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186381d1501318988-my-x-type-projects-installs-011-1.jpg)
nexxia radio adapter
![Name: 015.jpg
Size: 121.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186382d1501318988-my-x-type-projects-installs-015.jpg)
this is my first grille
![Name: wingpics108-2.jpg
Size: 51.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186383d1501318988-my-x-type-projects-installs-wingpics108-2.jpg)
my second grille
![Name: knegrille009.jpg
Size: 56.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186384d1501318988-my-x-type-projects-installs-knegrille009.jpg)
lowering springs
![Name: 100_0186.jpg
Size: 183.2 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186385d1501318988-my-x-type-projects-installs-100_0186.jpg)
Received 9,007 Likes
![Name: T15ESSJAG5.jpg
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186349d1501318966-my-x-type-projects-installs-t15essjag5.jpg)
![Name: AudiX6JYM-2.jpg
Size: 6.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186350d1501318966-my-x-type-projects-installs-audix6jym-2.jpg)
![Name: T15ESSST101-1.jpg
Size: 9.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186351d1501318966-my-x-type-projects-installs-t15essst101-1.jpg)
![Name: tshirt03-2.jpg
Size: 6.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186352d1501318966-my-x-type-projects-installs-tshirt03-2.jpg)
Hey Dennis,
pics have't came thru. try reading the " how to post pics " in the Jaguar help n suggestion centre.
Jim
One would think a MOD or an almighty Admin would get off their pompass butts and edit his posts and put in the [img][/img] tags for him...but Noooooooo!![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
Oh sit back down Jim..I'm just kidding![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![Name: 011-3.jpg
Size: 123.2 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186334d1501318944-my-x-type-projects-installs-011-3.jpg)
![Name: 010-2.jpg
Size: 92.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186335d1501318944-my-x-type-projects-installs-010-2.jpg)
Size: 117.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186336d1501318944-my-x-type-projects-installs-light009.jpg)
Size: 120.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186337d1501318944-my-x-type-projects-installs-light007.jpg)
Size: 97.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186338d1501318944-my-x-type-projects-installs-light011.jpg)
after painting
![Name: 011-1.jpg
Size: 153.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186339d1501318944-my-x-type-projects-installs-011-1.jpg)
![Name: 015.jpg
Size: 121.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186340d1501318944-my-x-type-projects-installs-015.jpg)
Size: 51.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186341d1501318944-my-x-type-projects-installs-wingpics108-2.jpg)
my second grille
Size: 56.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186342d1501318944-my-x-type-projects-installs-knegrille009.jpg)
lowering springs
Size: 183.2 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/186343d1501318944-my-x-type-projects-installs-100_0186.jpg)
yaron369 (07-17-2012)
