Oops, i did it again!! customize boot Plinth on a 2004 X-type
Just wanted to share an idea i had that made a reality. I went ahead and customized my chrome boot plinth on my 3.0 and wanted to share with you guys. I cut out the "Jaguar" and added an LED light strip in the back. So now my "jag" lights up when i turn on my headlights. Nice challenge, but well worth it!
The following 17 users liked this post by mad_mike:
Aonsaithya (02-27-2013),
Belfast Boy (02-28-2013),
Bruce in North Dakota (02-27-2013),
Cambo (02-27-2013),
dcgun (05-10-2022),
and 12 others liked this post.
I didn't take a lot of pix but will upload what i have. I'm not sure if you can do this if you have a 2.5 since the ones i've seen around here have the trunk button on the back part and not underneath the boot plinth. But what i did was remove the chrome part (do this very carefully cause i broke all the screws that hold it to the frame).
I also bought a detail hand saw ( like a mini rotozip at harbor freight only cost me $10! ) i went ahead and drilled into the letters carefully and then grinded out the lined area.
After all the letters were done, i bought an LED white light strip ($39.99) and gorilla glued it to the back.
i tapped into the licence plate light wire ( the right side light ) so when i turn on my headlights, it lights up.
mad_mike (02-27-2013)
Location: That Rectangular Hole in the Consciousness of America
It makes me want to grab my Dremel Tool grinder and run out to the Jag right now.
What I find most attractive about your mod is that it is so "seriously understated". The folks on the Jaguar Design Team could learn a bit from you there - especially after their major design misstep in using those gaudy LED lamps in the headlight surrounds of some recent models.
Now, if you could just get some tiny LED's into the eyes of the Leaper...
Well to answer the "?" About the water seal, the LED strip is for outdoor use and I just used the covers the came between the body and molding. I'm glad everyone liked it and I also posted a while back the side mirror LED mood. I put a strip of amber LED's behind the mirror so the turn signal glows behind the mirror.
Received 9,009 Likes
Thanks, I have been looking for that information!
I have an emergency boot opener with a lithium backup battery soon to be released that uses a (owner settable) sequence of button presses to open the boot/trunk in the event of a dead battery or keys locked in the trunk.
(Not trying to hijack this thread....please contact me or open another thread to discuss.)
