P1000 Is there any easy way?
Old 02-23-2011, 02:14 PM
nickpc2001's Avatar
Default P1000 Is there any easy way?
Hi,
I am in the process of selling my 03 jaguar X-type 5 speed. It currently has the P1000 code on it and I don't think I am going to have any luck selling it with this code on it. From what I have read you have to drive it certain ways etc.. before it goes off. The only instructions I found was for an automatic. Does anyone know of an easy way to get this code off my car?
Someone said something about resetting the codes then turn it half way on wait for a while then crank car and it should give systems time to check. Well any help would be great.. Thank You..
--Nick
Old 02-23-2011, 06:01 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
The car must complete the manufacturer's 'drive cycle' requirements to clear the P1000. There is little documentation on what the 'drive cycle' requirements are.
An example of a Ford 'drive cycle' can be found here: http://matt.zenfolio.com/ford-motor-...ving-cycle.pdf
Old 02-23-2011, 07:19 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Your drive cycles are described in the first few pages of this document.
Without diagnostic equipment, it is impossible to know for sure which parts of the drive cycle really are necessary. I know that here in VA, when we go for an emissions test, if the car fails due to 'not ready' status, the printout actually says what tests are not ready...that is really handy.
If you can post the fault codes you had before that were corrected with your last service, or at least the type of service that was done recently on the car, we probably can make an educated guess as to which parts of the drive cycle you actually need to do.
File Type: pdf
The following 2 users liked this post by WhiteXKR:
luisgobea (02-27-2015), test point (02-23-2011)
Old 02-23-2011, 09:42 PM
joycesjag's Avatar
Received 1,703 Likes on 1,211 Posts
you should not be trying to sell a vehicle that YOU just cleared the fault codes on anyway, just MHO
RickBNA (02-28-2011)
Old 02-28-2011, 10:37 PM
RickBNA's Avatar
I could not agree more!!!
And it is OBVIOUS from the original post that clearing the code in order to sell the car and NOT being a stand up guy is the poster's intent.
Sorry... I say things out load because I AM NOT politically correct!!
Old 03-01-2011, 07:24 PM
Quiet's Avatar
Default P1000
After 16 yrs of teaching Ford OBDII drivability and the Xtype basically running Ford software. P1000 is a normaly occurs after the Dtcs are cleared. It does not indicate a fault but as in previous thread just means not all of the OBDII monitors have completed.
Old 03-01-2011, 07:53 PM
Glendoramike's Avatar
P1000 just means that codes have been cleared out. It will automatically change to P1111 which means that the components have passed their tests. Go to www.canobd2.com if you want to get code definitions.
This happened to me after I went to the Jag dealer to clear up dumb recalls before going to get a smog test. The car failed. What is going on is that it used to be that people could pull their ECM fuse or disconnect the battery for at least 15 seconds and all the codes would be gone. They would then go to the test and most likely the codes won't be back yet. So now the computer wants to see a number of pass the test readings before switching to a P1111.
The dealer told me to drive 300 miles and all would be right. WRONG!!!! I figured that I would need to run a number of tests before it would pass. So, I went on a drive and I would stop every so often, turn the engine off, wait about 30 seconds, restart and dirve some more. I did this for what must have been about 10 times including the starts since the dealer cleared the codes. It then passed.
Johnken
04-08-2018 10:21 AM
ArtyH
10-02-2015 11:39 AM
convincor
10-01-2015 05:19 PM
Amberlinder541
09-30-2015 07:07 PM
Amberlinder541
09-26-2015 01:10 PM
Quick Reply: P1000 Is there any easy way?
