Pulled code P1603? EEPROM Malfunction?
Guest
Posts: n/a
After installing my new battery which fixed the "gearbox fault" issue and not turning over, I pulled the codes from the Jag. Got the obvious P1111 for completed diagnostics, but also pulled the P1603, which is the EEPROM Malfunction. I have no idea what that is or if I should be worried. Help? Thanks
-Chris
-Chris
Received 9,010 Likes
Dickie_L_J_O
09-13-2015 07:44 AM
2007, code, description, eeprom, error, fix, gearbox, jaguar, malfunction, malfuntion, p1603, passat, type, vw, xkr
