x-type
I went to look at the faq but i am not able to view as i am a new member.
let me ask a quick question, I have to replace 2 studs on the rear hub. long story, my wife hit a curb and the lugs were on so tight that i snapped 2 studs trying to remove the broken wheel. as it was windy and 30 degrees out i was not happy. I'm looking but i cant figure out the stud size, any ideas?
Received 9,010 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/175635d1501294443-x-type-car01.jpg)
Hey Digger, welcome to the forums, good to have you here
There's some great members here, techs are the best and always plenty going on.....check out the off topic section / detailing section and regional sections too!
I've manually upgraded you to Full forum access so you can better enjoy all the sites features
Get stuck in to that FAQ.......
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/175623d1501294423-x-type-car01.jpg)
digger, please do yourself a favour and check out our vendors section....We have some excellent Jag specialist vendors who have a great name for price / service and reliability on site for supplying a wide range of spares.
I'm positive they could sort you out with what you need very quickly
good morning all, its been a while since i've been on. two teenaged girls, i have to fight for computer time in between running them all over town.
also the jag has been in the body shop for a couple weeks thanks to a work truck backing into me, about 5 grand in damages. i will try to post a pic.
i do have a guestion about my 2002 x-type 3.0
i had a leak in the coolant tank and replaced last year. replaced with a used one as it was all i could find at the time. i has now started leaking. i found a new one to replace it with, but before i do an damage another one, is there something i should look for as the cause or is this something that happes often. i did see the same stress fractures on both tanks in the same places- right on the inner seal were they are joined.
what do you think.
what do you think.
Received 3,905 Likes
digger, unfortunately, that is a design flaw of the tanks. The only "fix" (use this term loosely) that I have heard of is people have used a drill and gotten rid of the piece on the tank and then went out and bought a brass bar piece to slide in there in place and then used some epoxy to seal things back up. Not sure how long it would last, but so far things seem to be holding out.
The other option you can try (not sure how it would work) is to get some thin super glue and epoxy. Then at each end where the crack is just starting, drill a small 1/16" to 1/8" hole to stop the crack from going any further (stress relief hole) and then use the epoxy to fill that hole. Then you can stress the tank just slightly to open up the crack and put a drop after drop of the super glue along the crack until the superglue has filled the crack. The superglue will wick along the crack due to capillary action (hence why I talk about the thin superglue).
Hope this helps you get things figured out. May want to try it on an old tank first to get the hang of what is happening here. That way if things go south on you, you are not out anything.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
