[Middle of job help needed] Size of lock/jam nut against inside of outer tie rod
Hey dudes,
My 2 biggest 18mm or 7/8 wrenches aren't fitting around the nut. Anyone know the exact size to go out and buy? Looks like it is going to be a beast to loosen, I need an exact fit. Help please
Thx dudes
Thx dudes
If you don't get an answer, try this:
snug up a adjustable wrench on the nut, remove wrench, measure.
At that range of sizes, the gap between wrench sizes is 2mm. So, you do not need really high precision to get the right measurement.
If you do not have a metric ruler. Just wrap black tape around the adjustment to keep it still and take the whole wrench on your shopping trip.
If you can get a flarenut wrench in the right size, you will be much better off than with the standard combination wrench.
Thx!
I think I got the job done right, but does the nut that goes around the bottom of the tie rod under the knuckle keep turning when tightening to where it does not stop moving? I know I am working with a ball joint mechanism, but it feels very unusual when I can keep turning the nut even when it is all the way up against the knuckle -yikes!
Is this normal?
Thanks dudes
Is this normal?
Thanks dudes
Are you sure you have the correct tie rod end? Do you see the shaft turning as you try to tighten the nut? The shaft end that goes through the knuckle is tapered so has you tighten the nut the shaft gets wedged into the knuckle, which keeps it from turning and the nut will tighten. Don't put any lubricant or anti-sieze on the shaft! You can try tapping lightly on the top of the tie rod to try to seat the shaft into the knuckle. Usually hand pressure will keep the shaft wedged enough to keep it from turning while you tighten the nut.
I checked the thread on the tie rod, it is fine. Yes, aftermarket tie rod. I was using my monster torque wrench when tightening, it got tight and then easy. I have snapped bolts in half with this torque wrench when getting nuts cross-threaded, so I put too much juice on it. I should have just used my socket wrench
this is the torque wrench I used
http://www.amazon.com/gp/product/B00...F8&me=&seller=
I got problems with my nuts
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
