02 sensor upstream
There are two upstreams and two downstreams. One of each for each bank. Which are you looking for, bank 1 or 2? One O2 is screwed into the cat converter and the other is right next to cat on the exhaust on both banks
If you found one already, just follow the wiring from the harness. The harness plugs are right out in the open on both banks. One set of plugs is back on the firewall by the brake booster and the other is up front in the water pump area by the battery box.
