02 XTYPE starting problem
02 jag xtype starting problem
so, i thought my battery went out, and so i tested it and it was fine. alternator checked out when i was at autozone too. now when i try to start it, the gauges just fluter, doesnt turn over, and for a short while, i could get a jump start, & it will start.
is it possibly the starter has gone out?
i took the battery out and had it tested at autozone. i had them test it twice because i was certain that was the problem.
it doesnt always start with a jumpstart.
sometimes, ill jump start it, then drive it for a few days, then it wont start. this last time, it started fine, went to store, had to get a jump start, then came home, took battery out..tested it the two times in a row at autozone, and then reinstalled the battery..still didnt start, so i tried to jump it again, and the gauges just flutered like they do everytime it doesnt start.
so, you dont think it is the starter?
2002 jaguar X-type.
well, i charged the battery on 2amp until the green light on my charger at home came on, which was only ~30min. then took it to autozone to assure my-self it wasnt the battery, which tested good. so, i reinstalled it and put it in #2 ignition, didnt see a light on the j gate light up. then i tried to start it and, it still didnt start, nor any light near the j gate.
i did notice that there is a 1/2 inch crack on the neg terminal
i suppose the light might have came on for a second, but i didnt notice it both times.
I have this problem and you guys have just about convinced me to go and shell out for a new battery, just one doubt on my mind, when the problem occurs...dash flashing, no start, why can I start the engine by shorting the ignition relay? The Starter turns with ease and the battery appears full of beans.
