03 x type erractic lights.........
Ok folks,
We got through the hesitation problems and running like a true Jag.
My other problem is truly wierd and maybe the car is just haunted.
It concerns rear brake/tail lights.
When lights are on and brake is applied,tail lights go out and yellow directionals come on(dim).
When lights are on and car is put in reverse,instead of reverse lights yellow directionals come on(dim).
Blinker speeds up if brake is applied as well.
All the time,3rd brakelight is unaffected.
I know you guys can point me in the right direction......
Thanks in advance,
Bowhunter
Thanks in advance,
Bowhunter
bowhunter72 (12-05-2014)
Received 3,932 Likes
bowhunter, sounds like your ground wire is getting damaged. PUll off the plug to the tail lights and check the second pin in and see if it is discolored (ie, overheated). If that is the case, you will need to clean up the terminals and restore them back to a silver state. Otherwise, you will need to do some looking around and seeing if you can find some new pins for the connector and hope that the heat damage hasn't progressed too far up the wiring.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
