03 x-type hid kit install guide?
It's actually pretty straightforward. There is very little room to work with however, so I would suggest taking the front bumper off so you can take the headlights out as mentioned above.
The only thing I had trouble with was the passenger side. Wiring is a little different as the ground and positive wires are in one connector. Driver's side has them separately which connects to the bulb perfectly. I had to ground the ground wire from the HID kit bulb to the chassis in order to get it working on the passenger side.
rsa760041
23
09-25-2015 01:33 PM
